Scan, trace, design, print, fixed!
Back to overview
Lost your mouse battery lid? Here's how I took care of mine...
Neon22 wrote 02/21/2018 at 20:03 point
You can also take a picture with your phone (as parallel as possible and as far away as possible). Drop it into Inkscape and use the "Realscale" extension to resize it to a precise dimension using any measureable feature. Then use the "export to openscad" extension, set the thickness and print.
- https://inkscape.org/en/gallery/%3Dextension/
- https://inkscape.org/en/~Moini/%E2%98%85realscale-resize-by-line-of-known-length
- https://www.thingiverse.com/thing:1065500
randallohman wrote 02/25/2018 at 19:38 point
Excellent. I teach 6th graders and I have them cut their 3D modeling teeth on OpenSCAD. They love to bring in images and use MS Paint to convert .jpg's to .png's necessary for the import.
raheez2121 wrote 02/21/2018 at 19:29 point
How is work in this company.is it MLM company
