Solder Paste + Hot Air Rework
A project log for Soldering Iron Ring Light
Light integrated into soldering iron to illuminate what I'm soldering, and learn a bit about SMD design and getting PCBs made
linus-dillonLinus Dillon 04/30/2015 at 11:060 Comments
I've now had a go at using some solder paste and heating it to the required temperature using hot air.
Turned out fairly neat. I did have trouble working out what temperature worked though. The resister was done with air at full blast and it almost got blown off the board. I dialled it down on the LEDs, but they then seemed to have trouble reflowing the paste, even at 350℃ (must check how hot it REALLY is though).
I might try the skillet method next. I think that may give the best and easiest results for SMD ICs.
