CVS Log to date.
A project log for Share the Warmth
Warm-air distribution system (PIC/JALv2)
sbigaijinsbi.gaijin 04/29/2015 at 07:490 Comments
The story so far, as told by the CVS log entries for main.jal:-
RCS file: /store/CVS/Heat_Vent/PWM/main.jal,v
Working file: main.jal
head: 1.10
branch:
locks: strict
access list:
symbolic names:
keyword substitution: kv
total revisions: 10; selected revisions: 10
description:
revision 1.10
date: 2014/01/01 11:40:13; author: cvsusers; state: Exp; lines: +9 -9
Commented-out the USB defines and the few USB calls that were still left
(now using XPort for I/O and debug messages).
revision 1.9
date: 2014/01/01 03:07:48; author: cvsusers; state: Exp; lines: +3 -2
Added initialization of owbus_direction to "input".
Changed OWSearchnTell() timing to once every 30 seconds (for testing).
revision 1.8
date: 2014/01/01 02:32:47; author: cvsusers; state: Exp; lines: +7 -7
Changed OWDEBUG constant to a bit (from a byte) to use boolean logic (as
it should have been from the start).
revision 1.7
date: 2013/02/28 22:53:46; author: cvsusers; state: Exp; lines: +25 -12
Added small loop to trigger one-wire reads based on a settable minute
count (from 1 to 255 minutes).
revision 1.6
date: 2013/02/26 21:51:35; author: cvsusers; state: Exp; lines: +27 -1
Added in one-wire support.
revision 1.5
date: 2013/02/26 21:25:46; author: cvsusers; state: Exp; lines: +64 -35
Updated to use dutycycle-ratio. Changed "PWM_lr" variable to "PWM_ratio" globally.
Added a second timer slot to the interrupt-driven delay routine.
Added a short routine to limit the number of PWM updates to a maximum of
five per second to help stability.
Updated omments in a few places.
revision 1.4
date: 2013/02/05 12:29:19; author: cvsusers; state: Exp; lines: +411 -39
Added xport.jal and xport_defs.jal to support serial debug using the
XPort module connected to the serial port lines.
Minor change to voltage specifier in calc_table script.
Added xport support to the Makefile.
Added tons and tons and tons of changes to the main.jal file (because
the CVS server was down for a couple of weeks) to support the XPort and to
try adding PID (proportional, integrated and differential) control
to the PWM/ADC feedback loop. Somewhat less than successful (the old
method of using a set value depending on the output offset worked
much more reliably).
revision 1.3
date: 2012/12/22 13:17:39; author: cvsusers; state: Exp; lines: +3 -1
Added USB flush command into top of forever loop to ensure that
the USB gets serviced on a regular basis.
revision 1.2
date: 2012/12/22 11:54:52; author: cvsusers; state: Exp; lines: +36 -29
Updated to use "pwm6" instead of "pwm1" (valid PWM output on pin 27 now).
Updated to initialize USB (unsuccessful).
revision 1.1
date: 2012/12/16 01:28:40; author: cvsusers; state: Exp;
Simplified main.jal for testing PWM and ADC routines.
