fanKnob.scadsource code for editing with openscadx-openscad - 961.00 bytes - 02/18/2018 at 03:38 |
fanKnob.stlReady to slice and print. Print with the outer face down to avoid using support. Print with several outer layers so the inner mounting hole has enough strength.sla - 186.24 kB - 02/18/2018 at 03:34 |
