Figuring out the Breakout Boards [pt2]
A project log for Nixie 'Display of Things'
Use a combination of six Nixie tubes with a 16x2 LCD display and Pi2 with Adafruit Proto-Perma HAT to display information.
jon-davies-woodyJon Davies "Woody" 05/17/2015 at 16:080 Comments
Using a previous blog post 'Figuring out the IN-14 Nixie Tubes and Break-out Boards', I checked the pin numbers that relate to the display digits and probed the Tube-to-Pin Header connections with my Continuity Tester. From these tests, I noted the pinouts with the display digits for future reference.
