Interface between glasses and sensors - Kimmy the Cat casts deciding vote
A project log for Peril-Sensitive Sunglasses
A version of the Peril-Sensitive Sunglasses (as described by Douglas Adams in The Hitchhiker's Guide to the Galaxy)
minimum-effective-doseMinimum Effective Dose 03/27/2014 at 02:300 Comments
This is a prototype and also development hardware, so it won't be size-optimized.  Size-optimizing is usually the opposite of "easy and accessible to work on".
The sensors will be separate from the glasses, allowing development to happen in a reasonable fashion while leaving the known-good part (the glasses, so far) separate.
The interface between the glasses and the peril-sensor package can be wired (easy, reliable, cheap) or wireless (more expensive, more complex, possibly not feasible.)
Wireless is tempting.  There is a small amount of space inside the glasses frame where the PCB goes. Power is also required.  There is room for a small li-po cell but space is very limited - none of the wireless units I know of will fit in that space (never mind the microcontroller most of them need as well.)
Wireless looks like a nonstarter at this stage of the game but tempting enough that I spent time investigating the options.  They weren't encouraging.
Whether to go wired or continue spending our limited time investigating further was put to a vote amongst the project members.
Should options for making the interface between glasses and sensors wireless continue to be explored?  Yes, No, or Abstain
2 votes no, 1 abstain.  The glasses will have a wired interface to the peril-sensing sensor box.
