Fix for a coffee maker Jura Impressa 300 with high temperature glue & 3D print
simplify3d_gcode - 914.20 kB - 02/19/2018 at 22:05 |
simplify3d_stl - 78.01 kB - 02/19/2018 at 22:05 |
After 24h waiting to cure the glue, assemble the machine. It looks well so far - the long term stability has to be proofed still - But the the challenge is gone :-)
That part is hot and wet. So I thought just glue will not work. So I thought glue with a shelf around could work. The shelf takes the pressure and the glue seal the liquid.
I used ABS with the finest resolution (0,2mm) my printer makes and a glue which works up to 120 deg. which is flexible and has the capability to fill gaps. The combination I thought should work perfectly.
For drawing and fixing the coffee maker I required appr. an hour. The glue was slightly more expensive than the spare part - but if the ...... German supplier don't want to deliver to Switzerland what choice you have?
