know your regulator
A project log for Ignore this ESP8266 board
I stole from every one. The huzza from Adafruit. Matts breakout board. Al1s board from here. NodeMCUs DevKit.
davedarkodavedarko 05/30/2015 at 14:430 Comments
When "designing" [stealing] this board parallel to the talk for the #ESP8266-01 Breakout I placed an LD1117AS33TR in my schematics while Matt used an LM1117 on his board. At this time I was only looking for a 1117 in the eagle library and added it. Turns out that I'm still in luck, since both only need 2 capacitors and all I had to do to fix this is order some 100nF in 1206.
