SmallBearingBody.stlThis, and the following 2 files are for people that want to try the bearing design themselves, but don't want multiple days of printing.Standard Tesselated Geometry - 109.36 kB - 02/21/2018 at 23:30 |
SeeThroughSmallBearingTop.stlI used variable layer height in Slic3r(Prusa Edition, a much better version than the original IMHO) to print the slopes at 0.1 mm. The rest should print fine at the highest layer height your printer can support. Also, please don't try to stand on this one. If you really want to try it then use the more robust one above with a 25%+ infill percentage.Standard Tesselated Geometry - 150.57 kB - 02/21/2018 at 23:31 |
SmallCones.stlget ready for a wall of text...I printed these at 0.15 mm, but you can most likely get away with at least 0.2 mm. Note that the whole small prototype was printed with a 0.25 mm nozzle, so I don't know how well it will print with the standard 0.4 mm. Also, you will have to print at least three batches. My version has 29 cones in it, but it does work with 27. One last thing, the thin plane on top of the whole thing was a quick and dirty trick so that I could export a chunk of cones at one time. It should be thin enough that the slicer should ignore it. Happy Printing! Standard Tesselated Geometry - 342.76 kB - 02/21/2018 at 23:29 |
Standard Tesselated Geometry - 87.58 kB - 02/20/2018 at 12:29 |
Standard Tesselated Geometry - 165.22 kB - 02/20/2018 at 12:29 |
Standard Tesselated Geometry - 141.68 kB - 02/20/2018 at 12:29 |
step - 112.79 kB - 02/20/2018 at 12:29 |
Standard Tesselated Geometry - 107.50 kB - 02/20/2018 at 12:29 |
