Hackaday.io Hackaday.io
Sign up Log in
ESP8266 Web Server (Without Arduino)
How to build a web server with a $4 WiFi Module called ESP8266 without using an Arduino
rui-santosRui Santos
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
19.1k views
6 comments
326 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 0
  • Instructions 5
    • View all
  • Discussion 6
View Gallery
19.1k
6
326
36
Team (1)
  • rui-santosRui Santos
Join this project's team
  • Code
  • Schematics
  • More Details
MISC
completed project
home automation ESP8266 home automation esp8266
Related lists
Interessante Projekt
Merkliste für zufällig gefundene Projekte
This project was created on 05/23/2015 and last updated 11 years ago.
Description
This is a simple web server project that you can do with your ESP8266 without using an external microcontroller. For this project you need to flash your ESP8266 with NodeMCU firmware. You can find all the instructions to complete this project in the "Build Instructions" section below.
Components
  • 1 × ESP8266
  • 1 × FTDI Programmers
  • 1 × LEDs Electronic Components / Misc. Electronic Components
  • 1 × Breadboard Electronic Components / Misc. Electronic Components
  • 1 × Jumper wires
Build Instructions
Collapse
  • 1
    Step 1
    If you don't know how the ESP8266 WiFi Module works, first read this tutorial.
  • 2
    Step 2
    Flash your ESP8266 with NodeMCU, you can read this tutorial on how to flash NodeMCU on your ESP8266
  • 3
    Step 3
    Download this code and upload it to your ESP8266 as "init.lua"
View all 5 instructions
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Amer Nazir Awan wrote 09/28/2015 at 21:55 • point
has any one tried DHT11 with lua, always gives me erroneous results, but when I test same sensor with arduino UNO and even with ESP12E using arduino IDE the results are very stable and reliable.
Amer Nazir Awan wrote 09/28/2015 at 21:51 • point
Hi, I have tested this with ESP12E module works very well, I have further added I2C expansion chip PCF8574 to get 8 additional outputs. and edited the code to control these extra outputs through I2C, works great. further I tried to work with DHT11 temperature and humidity sensor with no success.
xl2pfu wrote 07/22/2015 at 09:39 • point
Hi rui I cant use your init lua with Lua uplader. how can I do
Rui Santos wrote 07/22/2015 at 09:45 • point
you can use ESPlorer to upload the code. Here's the link http://esp8266.ru/esplorer/ Go to the tutorial section in that page and download my free "Getting Started With The ESPlorer IDE" pdf. I hope this helps!
xl2pfu wrote 07/22/2015 at 11:20 • point
okay I downloaded your program, at commands not problem but luad scripts full error :)  omg
roobertssuccess wrote 05/23/2015 at 16:45 • point
Hallo rui, i Love the esp8266, too.
Look At this: www.euerdesign.de
The very simple esp8266 management
Yet another levitator. Made to show at U of A DiscoverE camp "FUNday".
Project Owner Contributor
DiscoverE Magnetic Levitator
kskksk
How to make IoT projects with Blynk app and ESP8266 WiFi Arduino compatible module
Arduino ESP8266 Blynk tutorial - IoT project
geekstipsgeekstips
Wireless WIFI Anemometer using ESP12e
ESP8266 Anemometer
grahamGraham
A mini portable wifi controlled spike buster using low cost wifi device esp8266-01.
Portable WIFI controlled Spike buster(10$)
sathish-kumarSathish Kumar
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP8266 Web Server (Without Arduino)", please tell us the reason.
Send message
Remove Member
