Hackaday.io Hackaday.io
Sign up Log in
USB DEVBOARD v1 Based on V-USB
This project is a development of USBasp Programmer or similar that uses V-USB reference schematic but with more features that can be applied
banyyusufnbybany.yusuf.nby
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1k views
0 comments
1.1k followers
  • Description
  • Details
  • Files 0
  • Components 7
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1k
0
1.1k
2
Team (1)
  • banyyusufnbybany.yusuf.nby
Join this project's team
hardware
ongoing project
usb V-USB USBAsp DEVBOARD LEARNING KIT Atmega8 atmel
This project was created on 06/02/2015 and last updated 10 years ago.
Description
This project aims to create and develop similar devices such as USBAsp Programmer, Protrinket, USnooBie, etc. that uses V-USB schematic but provides access to some of the microcontroller pins that can be used by the user in the future.
Components
  • 1 × ATmega8 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × XTAL 16Mhz crystal oscillator
  • 4 × LED Fiber Optics / Emitters
  • 2 × 3v3 Zener Diode
  • 5 × Resistor
View all 7 components
Project Logs
Collapse
  • Create A Schematic and PCB Layout
    bany.yusuf.nby • 06/02/2015 at 12:01 • 0 comments
    This week schematic and layout has been completed and has been accepted in PCB printing services. I hope next week the PCB has been completed and can be taken and will continue into the next session.
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
An investigation into how effective is a USB-C socket made using PCB traces.
Project Owner Contributor
USB-C PCB Socket
gee-bartlettGee Bartlett
I modified the Mx Ergo to use USB C by reverse engineering the power PCB so that I could remake it with USB C instead!
Replacing micro USB with USB C the fun way!
solderkingSolderking
GC Joybus to USB Host Adapter, ST32F4xx based
GameCube USB Joystick
antti-lukatsAntti Lukats
A simple USB B to Micro USB Adapter PCB
sjm4306sjm4306
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "USB DEVBOARD v1 Based on V-USB", please tell us the reason.
Send message
Remove Member
