The Rythm Composter
Circuit Bending an old Roland Drum Machine using an Arduino Mega some cross-point arrays some schmitt triggers and a touch-screen
I've been circuit bending and hacking electronics since I was a kid. I really love old drum machines! But when it came time to circuit bend my Roland, I didn't want to end up with a grid of 100 1/4" phono jacks and a spaghetti of cables everywhere. So I wired up 3 CD22M3494 cross point array ICs to an arduino added an optoisolator for MIDI control and a touchscreen, and coded up a UI... Thus was born the 'Patch-a-tron-omatic'. The patch-a-tron is a 48x8 analog switch array for use as a solid state cable-less patch bay for circuit-benders and synthesizer. It's controlled by touchscreen and MIDI and is currently connected to my Roland TR-626 Rythm Composer from 1988. After that I cut into the clock traces on the Roland on 4 channels and replaced them with my own oscillators based upon a the Texas Instruments CD40106 hex schmitt trigger to allow me to 'pitch-bend' those channels. (All switchable of course!)
[Update: 2015/08/13] - Was out sick and my project updates suffered. Apologies to anyone who's been waiting for an update. My previous 'Sl33p i5 f0r th3 w33k' pace will likely now resume.
This was a very complex project with a lot to it. Most of the circuit modification to the Roland TR-626 are documented elsewhere. (Notably at - http://www.burnkit2600.com/tr-626-rhythm-decomposer/) The main difference between those projects and this one is the use of the Arduino Mega to control an addressable solid state switch array. instead of using cables.
Basically the patch-a-tron is a 'cable-less' patch bay.
The 3 CD22M3494 cross point switch array ICs share 18 of their 40 pins: V+, Gnd, the 10 switch address pins (4 bits for the x axis and 3 for the y), and the 8 x axis switch pins are connected in parallel for all 3 chips. Since they share so many pins it made sense to stack them.
16 wires from each chip are available for the patchbay. That's 48 switches on each bus. Since we have 8 buses, that's 384 switches we can control. To make it easier to navigate this is broken up into 8 screens, one for each patch bus. The switches are represented on the screen in a 6x8 grid. There's another row of 8 numbered buttons at the bottom that select which bus is displayed as well as activate or deactivate the switch configuration (the green dot means its active a red dot means it's inactive.)
The keypad on the right allows patterns to be saved into the EEPROM and recalled instead of having to remember what cable was plugged into which patch port. It also means that patterns and changes can be triggered by MIDI. (That's right. It has MIDI in too!)
The Analog switch array is configured as 48x8 with the 48 points being used for patch points on the Roland. (I'm actually only using 47.) The 8 axis is 8 'buses'. So the screen shows all 47 patch points that can be connected and the 8 buttons select each independent 'bus'. All 8 buses can be active at once. But only one is visible at a time.
In addition, it's got some safeguards that prevent a user from entering combinations or bends that are capable of crashing or damaging the Roland. For example The software will not allow the user to connect the positive voltage (Row 3 column 1) to the negative voltage(row 3 column 2) as that would short circuit the power supply. Other 'known bad' combinations are also disallowed. Similarly, the 8 'buses' will attempt to avoid each other. (i.e. if 2 bends contain the same bend point, only 1 can be active at a time. ) This helps keep the sound from turning to 'mush' during complex bends or sequences.
Please bear with me while I compile all of the documentation for this project and add it this page. I'm adding things as I come accross them.
Source code for the 'patch-a-tron' is up an Github and should be helpful to anyone looking to use the CD22M3494 with Arduino. It basically uses 7 address bits to select the switch address, one to set it's state, a strobe and then one CS pin for each CD22M3494 chip used. The circuit uses parallel addressing (i.e. all of the chips are hooked up to the same address pins on the Adruino.) The CS pin on each IC is used to select which chip the Arduino is setting at any given time.
This project is released under the MIT license - http://opensource.org/licenses/MIT also available on the project github page
  • 1 × Arduino Mega
  • 3 × CD22M3494 16x8 Cross point analog switch array These end up being the 48x8 switch array
  • 1 × Adafruit RA8875 touchscreen controller board
  • 1 × 800x480 4.3" (or 5") LCD with touchscreen
  • 1 × Texas Instruments CD40106 hex schmitt trigger IC for our pitch bend oscillators
View all 22 components
  • Buttons, Switches and Lights
    Alpha Charlie07/24/2015 at 01:41 0 comments
    In addition to the touchscreen, the Patch-A-Tron has 2 LEDs, 9 momentary pushbuttons and a 16 key keypad for I/O. The 16 key keypad allows the user to save and recall configurations. The LEDs provide feedback on the keypad input. 8 of the 9 SPST buttons are used to select/mute/unmute the 8 channels of the Patch-A-Tron. The remaining button is a master reset that disables all bends and returns the configuration to 'stock'. It is the red button on the upper left corner of the TR-626.
    Connections are:
    • 16 key keypad - Rows pins 3, 4, 5, 6; columns pins 7, 8, 9, 10
    • 8 'Mute/Select' buttons - Pins 38 ,39, 40, 41, 42, 43 ,44, 45
    • RESET button - Pin 37
    • Programming LEDs - Pins 22, 23
    The Roland TR-626 has 8 SPST switches and 8 SPDT On-Off-(ON momentary) switches on the right upper corner which are connected to dedicated circuit bends. (the Momentary switches are the top row and are connected to the RAM of the TR-626**.) The four knobs and switches in the middle 'pitch bend' four of the Roland's output channels. With each switch turning it's respective pitch bend on or off.
    **The RAM bends sound really cool but must be turned off when not in use as they can make the unit unstable.
  • Patch-A-Tron RA8875 Video Controller
    Alpha Charlie07/24/2015 at 01:16 0 comments
    The Patch-A-Tron uses the RA8875 video controller board from Adafruit. This controller works via SPI and handles all of the low-level rendering as well as the touchscreen control. This makes it really nice for Arduino. Connection is via the 6 pin SPI connector in the middle of the Mega. (+Vin, GND, MISO, MOSI SCK, RST) with pin 11 on the Arduino being used for the INT and pin 12 for the CS on the RA8875.
    In the photo above the blue and green wires go to pin 11, and 12 on the Arduino the rest connect to the 6 pin SPI connector in the center of the Mega. Both the video out and touchscreen in are SPI, so wiring it is extremely simple. (Note also that there is a layer of Kaptan tape and another layer of 2 sided tape insulating and affixing the RA8875 to the aluminum plate. Which is not really visible in the photo. Without it the RA8875 would short out on the faceplate.)
    The Patch-A-Tron Arduino Sketch uses the RA8875 library available here -
    https://github.com/adafruit/Adafruit_RA8875.
  • Patch-a-Tron MIDI Implementation
    Alpha Charlie06/30/2015 at 23:36 0 comments
    Included in the Patch-a-Tron hardware is a MIDI implementation that allows the circuit bends in the Patch-A-Tron to be controlled remotely. The hardware interface consists of the standard MIDI DIN connector fed to the Arduino UART through by an opto-isolator, per the MIDI specification. (details at - http://www.midi.org/techspecs/electrispec.php)
    The schematic below shows how to connect MIDI hardware to the Arduino. The arduino should be connected via one of its hardware serial ports. [Patch-a-Tron uses port 2 by default on the Mega, pins 16(TX) and 17(RX)]
    The software currently only implements the Control Change and Program Change MIDI events with the idea being that the same sequencer could control both the Roland and the Patch-a-Tron and get repeatable - predictable - sequencable circuit bends that go with the sequenced rythm. Control Change allows the user to choose memory banks (A-D). Program Change selects pitch bends to activate. Banks A-C only save 128 bends per bank(0-127). Each 'bend' consists of one 'bus' of of max 48 switches. Bank D saves only 16 slots(0-15). But each slot contains the configuration for all 384 switches.
  • Pitch Clock Mod
    Alpha Charlie06/26/2015 at 03:19 0 comments
    Here is the basic circuit I used to create my own pitch clocks for 4 of the output channels. The TI CD40106 runs the 4 oscillators. Each has it's own potentiometer. The capacitor for each oscillator should be adjusted to taste for the channel you are modding so that the pitch variation is noticeable and pleasing to the ear when the potentiometer is turned...
    (Note - In the drawing below, the switch numbers are transposed on the right hand lower side... 3 should be above 4. Ooops!)
    The four oscillator signals run to the NO connections of the 4 switches in the Max394. The NC connections of each switch are connected to the actual Roland TR-626 pitch clocks signals on the gate array(IC 13). The COM are connected to the clock inputs on IC14 of the TR-626. This allows me to choose between the Roland clocks and my pitch modded clocks with the four spdt switches.
    * The value of the resistor connected to each LED will depend upon the diode forward voltage and current for the LED. 150-330 ohms is typical. (there's a calculator you can use here if you know the specs for your LEDs.)
    ** The value of the capacitors for each oscillator will be dependent upon the clock signals you are replacing and how far you wish to bend them... the frequency out will be around 1/1.2*RC (just count the 500K pot and the 1k. Ignore the diode/1k leg in the freq calculation. It's just there to keep the pulse width low on the generated signal. The Roland clock is not on a 50% duty cycle. It generates fixed width pulses...) For the caps themselves I use polyester or mylar. I started with 0.1uF and adjusted from there by ear. USe a larger capacitor for a lower pitch, a smaller capacitor for a higher pitch. To limit the highest pitch reachable on the high end, you can increase the 1k resistor connected to the pot to 3.3k or 4.7k. The pots are 500k, If you can find them use reverse logarithmic pots. Linear will work in a pinch but adjusts the frequency linearly, which is not how humans perceive pitch.
    If you decide to try this mod- Be Careful! Installing this circuit in the Roland is a nightmare. It was 100% the most difficult part of the entire project. Both IC13 and IC14 are SMT chips and doing this mod means either desoldering one of them or cutting traces on the board. Neither option is easy. Below is a video showing the mod. You can see what I mean.
    Also- unlike the Patch-a-tron which requires minimum tools to construct, an oscilloscope is almost required to troubleshoot this mod if anything goes wrong.
  • Switch Array Stack
    Alpha Charlie06/23/2015 at 08:25 0 comments
    The heart of the Patch-a-Tron is the stack of 3 CD22M3494 crosspoint array ICs. Together they control the 384 analog switches that turn our bends on and off. The IC uses 7 pins for addressing, 1 for switch data and 1 as a strobe (or clock) to time things. All of these pins and also the 8 x-axis pins and the positive and negative power pins are all connected in parallel for all of the ICs. Since the ICs share over half of their pins, it made sense to me to stack them vertically and run all of their common pins through a 'bus' of parallel wires.I used Busboard 'zig-zag' trace prototyping board (part no. BB02) for the stack and cut it to size because the zig-zag trace pattern offered the easiest routing.
    Below is the board layout and wiring diagram for the switch stack. The entire circuit consists of 3 boards layed out as below each with it's own CD22M3494, all stacked together vertically. (Sorry there's no schematic yet. I literally designed the circuit in 3 dimensions in my head, then just constructed it. It has never been drawn out fully in 2 dimensions...)
    And below you can see the finished stack of 384 analog switches! (the wires all go to the Arduino, the 16 switch connections for each IC are the male dupont headers on each layer).
    Below is a schematic of the interface between the Arduino and the 3x CD22M3494 ICs. One thing that is worth ntoing about the CD22M3494 is that is has a separate logic ground than signal ground. The Vss pin is for the logic that controls the switches. The analog ground for the signals is the Vee pin. This is a nice feature escpecially if you're mixing different systems together. But since I already tied the Arduino into the Roland power supply, I ended up putting an SPST switch between Vss amd Vee so that I can selectively tie them together or not (whichever has the least noise).
  • Patch-a-Tron Walkthrough
    Alpha Charlie06/21/2015 at 10:22 0 comments
    This video shows a walkthrough of how the patch-a-tron UI works.
  • TR-626 patch-a-tron demo
    Alpha Charlie06/21/2015 at 10:18 0 comments
    This video shows the Patch-a-tron after it's marraige to the Roland TR-626 but prior to the pitch clock mod.
  • BreadBoard Demo
    Alpha Charlie06/21/2015 at 10:01 0 comments
    This video shows the patch-a-tron right after I made it, hooked up to a Roland TR-505 (I didn't know whether it would work and didn't want to waste my precious TR-626.)
View all 8 project logs
Alpha Charlie wrote 06/24/2015 at 23:51 point
thanks! I should have the remainder of the patch-a-tron schematics up by this weekend.
Jordan wrote 06/24/2015 at 22:59 point
Sweet design, hope you give us more updates!
