Finally!
A project log for operation: Learn The MIPS (PIC32MX1xx/2xx/370)
Having been exclusive to a certain uC-line for over a decade, it's time to learn something new (and port commonCode!)... Enter MIPS
eric-hertzEric Hertz 08/11/2015 at 14:290 Comments
Things're getting a bit confusing 'round here, as many of my projects feed into each other... This project is a relative-go, as I've managed to get the early-stages of #commonCode (not exclusively for AVRs) running on the PIC32... First was 'heartbeat,' which was a bit of a hurdle because I didn't realize the default ADC-register-settings interfere with many GPIO pins. (I think there's a log about that). Also, some difficulties with the timer, and a few other settings here and there... (FYI: read carefully: the "primary oscillator" is *external*, most-likely for early testing you'll want the FRC "Fast R/C" oscillator, which is internal (also note, it's not highly precise... mine's running at 108%). The weird thing is... even when selecting an external oscillator, it actually ran... maybe the breadboard capacitance did it, or maybe the PLL doesn't run slower than a certain frequency, so assumes it's there... I dunno.
OK, after 'heartbeat' usually comes 'polled-uat' which is a bitbanged UART (with only a transmitter). This should be an easy step, since the heartbeat's default functionality already assures the timer is set-up...
The third step is usually 'polled-uar' which is the bitbanged UART's *receiver.* Again, this should be an easy step; the timer's already set-up, and the heartbeat code also has Input functionality running (push a button and the heartbeat changes from fading to blinking). Right, again, easier said than done... Apparently I chose a pin who, again, had *different* defaults than GPIO... So, rather'n fight it, I just ended up swapping to another pin.
But, it didn't work. First-guess, the 108% thing was too much for bitbanged *input*... PCs are probably a bit more sophisticated in their UART reception than my code. So I scaled out that error... and everything died. And it's been dead for nearly a week. FINALLY I figured it out... My scaling managed to push some math to overflow... Actually, that was one of my earlier guesses, but my calculator (which I wrote) said it should fit in 32bits fine... Low-and-behold, my calculator was only showing the lower 32 bits, and actually the scaling needed 36. Woot! DAYS UPON DAYS to figure that shizzle out.
On the plus-side, my calculator is new and improved! My polled_uat code has been cleaned up quite a bit, as well as a few other things here and there. Also some new ideas for abstracting 'heartbeat' a bit more.
Anyways, suffice-to-say, these three 'commonThings', once running, are usually the basis for all my projects... and now we're ready to start a new, more-sophisticated project... Enter: #2.5-3D thing, wherein I'll be abstracting the motion-control aspects of 'commonCode' so they can function on PIC32, and hopefully more-easily be ported to most any architecture.
