First DIPSY "DIY" Kit shipped!
A project log for DIPSY
DIY System on Chip based on FPGA, priced below 5 USD
antti-lukatsAntti Lukats 08/22/2015 at 18:4313 Comments
DIE HARD KIT 1
1) DIPSY easysolder PCB with FPGA assembled
2) DIPSY easysolder PCB without FPGA
All the SMD components needed to fully assembley 2 DIPSY boards..
Christoph wrote 08/25/2015 at 21:58 point
Well, until now I just finished the pre-assembled pcb, which had the FPGA already mounted. I had to add two 0201 caps, one 0201 resistor, and the sot-23 voltage regulator. The passives are extremely small, and I'd rather not do that again by hand. But the dipsy works!
Antti Lukats wrote 08/26/2015 at 08:10 point
Hyper super done, that really is really good to hear. I mean it.
But those 0201, they are not 0201, they are 0402, that's why it is called easysolder! 0201 are really pita, but still doable if there is room enough for the solder tip. Dense placed 0201 are really bad.
Christoph wrote 08/26/2015 at 08:15 point
OK then, but smaller than anything I've ever done before and they looked *a lot* smaller than 0603 so I thought "oh that must be 0201 then". I wouldn't want to try anything smaller than that...
Antti Lukats wrote 08/26/2015 at 08:34 point
Yes 0201 are not really for hand solder. Some young people do them without magnifier glass seen that 0402 is something that can be made to "stick" onto PCB usually 0603 are doable, 0805 are really easy to solder. It also depends a bit the footprint. And solder to use. With RoHS solder it is much much harder to manage.
K.C. Lee wrote 08/26/2015 at 10:21 point
I have used 0302 x2 resistor arrays.  While not for the average person, they are easier than trying to place/reflow two 0201 right next to each other.
Christoph wrote 08/22/2015 at 20:22 point
I'll keep you updated about how it turns out! This will be interesting to solder...
Antti Lukats wrote 08/22/2015 at 18:56 point
Honestly it is not meant to make life hard ,and force all and everyone to solder 0402 or smaller stuff. Just that the FIRST dipsy left as DIY kit..
[deleted]
Antti Lukats wrote 08/22/2015 at 18:54 point
funnily the MOST complex part is the EASIEST. The BGA package solders itself almost by magic. Some good flux, then you move it so that you do not see the PCB pads from the top, and into oven.. almost 100% yield!
Yann Guidon / YGDES wrote 08/22/2015 at 18:48 point
WHO can solder it by hand ??
Antti Lukats wrote 08/22/2015 at 18:53 point
Anyone younger or older than me, this is "easysolder" version of the PCB.. Ok the thing is that I wanted to ship something today and recipient was eager to solder ALL from scratch, so I added one extra bare PCB for this fun. One PCB is pre-assembled with the FPGA by me, so all that is needed basically is to solder the SOT-23 packaged LDO.
Dimitar Tomov wrote 08/22/2015 at 18:54 point
Very experienced person ;)) No doubt. But also it's good practice if you
want to get some experience with precise soldering. And the idea here
is that it enables a vast area for developing MCU using sand particles
to create a complete CPU ARCH + outside peripheral :)
Yann Guidon / YGDES wrote 08/22/2015 at 19:07 point
Dimitar Tomov yes the DIPSY is awesome and it puts even more pressure to complete my YASEP CPU :-D
Dimitar Tomov wrote 08/22/2015 at 21:12 point
Well that's more motivation. So overall it's ++ operation :P :D
