Hackaday.io Hackaday.io
Sign up Log in
PiSaint home automation board
Connecting Raspberry Pi to 230V Sainsmart relais
richard-deiningerRichard Deininger
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.2k views
1 comments
1.8k followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
1.2k
1
1.8k
5
Team (1)
  • richard-deiningerRichard Deininger
Join this project's team
  • PiSaint KiCAD Project Export
  • LieberLieber Blog
completed project
hardware
ULN2803 SainSmart raspberry pi
This project was created on 07/14/2015 and last updated 8 years ago.
Description
As shown in the "Sous Vide cooker and more" https://hackaday.io/project/5533-sous-vide-cooker-and-more I build a system to control SainSmart relais with the Raspberry Pi's GPIO. To use this system for a home automation project I built an open hardware PCB board for this. The board was designed to fit to the Raspberry Pi's mounting holes and utilize standard flat ribbon cables for connection.
Components
  • 1 × SainSmart 8-Kanal-DC 5V Relay-Modul http://www.sainsmart.com/8-channel-dc-5v-relay-module-for-arduino-pic-arm-dsp-avr-msp430-ttl-logic.html
  • 1 × Raspberry PI
  • 1 × ULN2803A Discrete Semiconductors / Power Transistors and MOSFETs
Project Logs
Collapse
  • Stackable PiSaint
    Richard Deininger • 08/06/2015 at 11:48 • 0 comments
    Here is the latest Update to show you the "stackable" implementation of the PiSaint
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Richard Deininger wrote 01/11/2017 at 13:13 • point
We finally created a new version,... see:
https://hackaday.io/project/19381-pisaint-20-home-automation-board
A open source board, converting the Pi's PCIe HAT into a PCIe x1 card.
Project Owner Contributor
open-HAT-PCIe
rextangRex.Tang
Pi Pico breakout with screw terminals and prototyping area for my projects
Raspberry Pi Pico Breakout Board
eric-wiiliamEric Wiiliam
yes it's out of date but fun and cool
pi boy
redred
PiRelay 8 Launched on Kickstarter on 01st July, 2021 A New Raspberry Pi Expansion "PiRelay 8 Smart Relay Board for Raspberry Pi"
undefined
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "PiSaint home automation board", please tell us the reason.
Send message
Remove Member
