This library is the Adafruit TFT Libraries changed to works in TFT 2.4 shields with the SPFD5408 controller.
I'm using this library with success, but I'm not able to find functions like bufferEmpty() that is found in the Adafruit_STMPE610 library.
Without this function I end up with multiple touches each time. Any tips would be greatly appreciated. Thanks!
In case it's of use to anyone else, I solved my problem by adding a delay between calls to waitOneTouch(). Apparently it's not a buffer issue, but rather a bounce issue.
Hi! I see different effects with the shield but it's not possible to use the touch and I have to pu each call to on waitOneTouch in comentary.
Have idea ? thanks
Th zip file downloaded is corrupt as per winzip. Please check
I downloaded the required library but getting only white screen. can you please tell me what's the reason behind it?
Just download and seem to have it kinda working... but I'm getting a split screen. so what ever you are displaying is split and is displayed in 1/2 the screen, and then displayed again in the other 1/2... so I see your text "Groop I Implore you... " displayed twice in 1/2 the screen as it rotates through printing in landscape and portrait... thoughts? I bought this TFT http://www.ebay.com/itm/172088465109?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
When I run theSPFD5408 Graphicstest with Adafrut unit16_t identifier code uncommented, I get
TFT LCD test
Using Adafruit 2.8" TFT Breakout Board Pinout
Found ILI9341 LCD driver
Benchmark Time (microseconds)
Screen fill 1322516
Text 421928
Lines 4214832
Horiz/Vert Lines 140444
Rectangles (outline) 104472
Rectangles (filled) 3069832
Circles (filled) 1365436
Circles (outline) 1841148
Triangles (outline) 1336944
Triangles (filled) 1749568
Rounded rects (outline) 613452
Rounded rects (filled) 3636560
Done!
any Ideas?
If this library works %100
Then, my display is broken!!
It's all white .. have been looking for days. I'm using uno
In my opinion this library is the best set I downloaded until today.
Take care with electronical contact. In first time, I have just one blank scrren and I pushed more the pins in UNO card.
Regards
Works only for ATMEL. What about STM?
