Gear Cutting
A project log for 2.5-3D thing
a tiny-but-scalable three-ish axis-system *from* laser-cuts
eric-hertzEric Hertz 08/25/2015 at 04:499 Comments
Found an image of the motors/worm-gear that seemed to be pretty much straight-on... so cropped and cleaned it a bit in gimp, then traced the bitmap into a path in inkscape, then output SCAD code via Make a 3D print from a 2D drawing...
Did some math... and I think I could actually cut a mating gear with a bit more math and measurements:
(Of course, this is the cutout-piece that will be subtracted from a cylinder)
frankstripod wrote 08/25/2015 at 19:55 point
Very creative using three programs for that :)
Eric Hertz wrote 08/26/2015 at 01:16 point
davedarko wrote 08/25/2015 at 09:47 point
Gears... should be a form of art. Good luck with them :)
Eric Hertz wrote 08/25/2015 at 10:11 point
Thanks! :)
There's sure to be some backlash, and a bit of math
left, to make sure the measurements are right (don't have the actual
ones on-hand, so have to work from limited data). But I'm kinda proud of
having come up with this process to mate with an unknown/unspecified
gear :)
Did you look at that link for the motors? I bet they'd drop-in on your yellow motor-gearboxes, if you want to add encoders!
davedarko wrote 08/25/2015 at 10:33 point
they look neat, but I've already exceeded my shopping limits... It's this time of year again, where I don't hack but only buy stuff :D
Eric Hertz wrote 08/25/2015 at 10:48 point
Did seem like your project-updates have slowed a bit, lately... now I know why!
davedarko wrote 08/25/2015 at 10:52 point
well this and work... I've crossed off two continents this year I've never been to before and was (actually still am) quite busy working. But now that I'm home I can use some time for projects again :)
davedarko wrote 08/25/2015 at 10:53 point
while I was traveling I had plenty of ideas and could only buy stuff for the projects and don't work on them too.
Eric Hertz wrote 08/25/2015 at 13:09 point
clearly you need to have a hacker-toolkit to bring everywhere with you!
