Making the field recorder into a small square box 15x15x7cm
The plan here is to mount the DSP digi card and analouge main board to
a 2mm 10x10cm sheet of aluminium which will hopefully shield the EMI from
digi board to analogue board ( preamps )
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
