preamp / line driver and HP cards in with +/-9v opa1637 buffers biased from VQ on ADC and DAC
A project log for Multichannel Audio DSP Field Mixer Recorder
bluetooth app controlled professional portable DSP mixer.balanced audio IO,phantom power,flexible routing,ISO recording. timcode. AVB audio.
ben-bilesben biles 10/06/2021 at 13:380 Comments
4 preamp cards and 4 balanced line drivers using OPA1637.
The Vcom and higher +/-9v rails for OPA1637 buffer are supplied through the stackable headers on the preamp cards. They are 1mm to long so not sure I will be able to squeeze all 8 preamps in there using those.
The 6mm brass standoffs worked fine for the line drivers and I send the VQ down one line of brass standoffs and it works.
