Divergence Meter Project
A project to make the Divergence Meter from the anime Steins;Gate a reality, functioning as both a clock and as the device in the anime!
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The Divergence Meter's Project aim is to recreate the fictional device called the Divergence Meter from the anime Steins;Gate. In my design the device functions as both the actual device ( of course without it's fictional abilities, only a recreation ) and as a daily use clock. It uses IN-14 Nixie Tubes as it's display, and the driving electronics were mostly custom designed. However some parts were based on the project by Tom Titor. I just improved some of the functionality of his. The project is open hardware and open source, available in my Github repo in the links section. Their are also project logs and more pictures on my blog also in the links section.
