1Step 1
Grab the latest release from the GitHub releases page. Or if you are feeling adventurous, clone the live source from the master branch.
2Step 2
Flash the core of Octoduino to your Arduino board. You MUST use PlatformIO, the Wiring Arduino IDE will NOT work. See the GitHub wiki for help.
3Step 3
Copy everything IN the ~/boot folder to a blank SD card that is less than 4GB big and formatted to FAT32.
4Step 4
Right now, there are no stable parsers available. See the instructions on the wiki to see how to get started writing your own.
5Step 5
Attach the Ethernet shield, stick the SD card in, then apply power. Make sure you have a serial window open (Please use the one provided by the Arduino IDE).
