EgDah ala HaDge
Alternative Hackaday Badge: Inspired by DIPSY.COOL
Features on the badge
  1. Main MCU: None
  2. Memory
    1. RAM: minimum 8K
    2. Flash: minimum 2M
  3. Radio: None
  4. Graphical Display: None
  5. on-badge Display Type: POV
  6. Capsense pads: minimum 4 ?
  7. UD Card Type III slots: minimum 1
  8. micro UD Card Type III slots: minimum 1
  9. micro UD Card Type I slots: minimum 1
  10. uNFC (ultra Near Field Communication) support: yes
  11. LiLi: yes
  12. DIPSY sockets: minimum 1
  13. Banana I/O Terminals (4mm plated holes in PCB similar to bbc.micro)
    1. 3 I/O
    2. GND
    3. 3.3V supply
  14. Crocodile clipse terminals: TBD (maybe combined with Bananas?)
  15. CRUVI (tm) Slots: minimum 2
  16. Magnet I/O Slots: 1 - TBD
  17. Main Power: Two CR2032 Coin cells (one is mandatory) -TBD
    1. One CR2032 for the main IC
    2. Second CR2032 for the peripheral and I/O
  18. Core static current: 100uA? (or 300uA?) - TBD
  19. 3D Gesture sensing: Si1143? - TBD
  20. Component BOM < 20 USD
Features of the Badge
  1. Main MCU
    1. Any -> design your own using Open Source FPGA toolchain!
    2. None -> use secondary MCU
  2. Secondary MCU
    1. Atmel SAMxx -> as add-on in micro UD Type I slot
    2. Atmel AVRxx -> as add-on in micro UD Type I slot
    3. abc.xyz -> as add-on
  3. Radio
    1. iSDIO Wifi -> in UD Slot
    2. BLE BCM747S based -> BLE.IO in micro UD type III
    3. Atmel SAM R21 -> in UD or micro UD type III
    4. Nordic LU1 -> micro UD type III
    5. FM Radio (RX/TX) > in micro UD type I
  4. Wired Connectivity
    1. USB - TBD
    2. SD Card shadow - TBD
  5. Storage
    1. 128GB+ (SD card or micro SD Card)
  6. Display
    1. TBD
to be continued...
  • Magnetic I/O Test
    Antti Lukats08/30/2015 at 11:13 0 comments
    using stuff from "grab box", here is video:
    using 3 magnets per contact
    Two magnets per contact.
    Use of 3mm Screws is also possible.
    Recommended PCB thickness 1.6mm, hole size 3mm.
View project log
