close-circle
Now with sub-projects!
A project log for ED-64: A discrete 8-bit computer
ED-64 will be an 8-bit computer built with discrete components, and will feature a ferrite core memory (documented as a separate project).
Andrew Starr 04/20/2016 at 09:171 Comment
The T-1 project blog is beginning to get a bit unwieldy, so I have decided to document the computer sub-systems as separate projects, and use this one as a 'top level' project to tie everything together.
The ferrite core memory is the first sub-project, it will be followed (eventually) by the ALU, program memory, etc. as I work through and build them.
Yann Guidon / YGDES wrote 04/20/2016 at 16:58 point
Yup, it's a good way to go :-)
