Mini PowerMac
The Mini PowerMac is a 1/3 scale computer, based on the Power Macintosh 5200LC.
The Mini PowerMac is a 1/3 scale computer, based on the Power Macintosh 5200LC. It's powered by an ODROID-W running Debian Linux, configured to boot straight into Basilisk II, an open-source 68k Macintosh emulator running Mac OS 7.5.3.
Background
The original inspiration for this project came from Strider19's mini PC project, which fit a Raspberry Pi into an old novelty computer-shaped radio. I actually had one of these radios at some point during the nineties, so I immediately thought about building my own and wondered: has anyone made a Mac version? I then found John Leake's hand-made Mini Macintosh project, which provided further inspiration. From these, I identified my own project goals:
  1. Make something smaller than the two existing projects.
  2. Build it in an existing case.
  3. Cut as few holes as possible and keep external ports and cables to a minimum.
  4. Bonus: Keep the interior tidy and organized.
  • 1 × ODROID-W http://www.hardkernel.com/main/products/prdt_info.php?g_code=g140610189490
  • 1 × American Girl "Mini Macintosh" http://americangirl.wikia.com/wiki/Mini_Macintosh
  • 1 × 3.5" TFT LCD Monitor http://www.amazon.com/gp/product/B0045IIZKU
  • 1 × DC-DC Stepdown Converter (12V-5V) http://www.amazon.com/gp/product/B00CXKBJI2
  • 1 × 4-port USB Hub http://www.amazon.com/gp/product/B003M0NURK
View all 7 components
  • 1
    Step 1
    Selecting Hardware
    Case
    Searching online, I found the "Mini Macintosh", an accessory from the American Girl doll catalog that was released in 1996. This toy version originally had a 3.25" monochrome LCD display that showed static images as seen in this YouTube video. I thought it'd be perfect, so I bought one on eBay.
    Computing Module
    Once I got it in my hands, I realized that a Raspberry Pi wouldn't fit in the case unless I started de-soldering connectors, and even then it'd be a challenge. Fortunately, around this time HardKernel released their ODROID-W computing module, which is a South Korean clone of the Raspberry Pi. It got some hate from the internet, but it's still an impressive bit of engineering so I ordered one immediately. (They've apparently been discontinued since then.)
    Display
    The screen comes from a Chinese automotive rearview display. I had previously tried a TFT display, but the drivers for this particular one aren't well-written so it flogs the CPU at 100% whenever it's in use.
    Power
    Since the screen runs best at 12V but the ODROID-W only needs 5V, I bought this DC/DC step-down converter. It takes anything between 12-24V as input, and outputs 5V at the other end.
    Peripherals
    I also included a USB Hub, USB Wi-Fi adapter, and a wireless keyboard/trackpad.
  • 2
    Step 2
    Preparing the Case
    I disassembled the case and found that it consisted of three pieces: a "lower" base with the battery compartment, the "upper" shell with power switch and speaker, and the front panel with screen.
    In the lower base, I slightly widened a hole where the original mouse wire entered and inserted a combination power and RCA cable. The cable was originally for a microphone, so all I had to do was cut it apart and spray it with a can of gray vinyl dye. The RCA connector will be wired to the secondary input on the display, so I can connect other composite devices as inputs to the Mac's screen.
    Shown above: The lower base with power/RCA cable.
    In the upper shell, I soldered JST connectors onto the power switch. The female plug is "input", while the male connector is "output", with the toggle switch operating as a simple open/close on the positive lead. There's a mono speaker (8-Ohm, 1-Watt) mounted in the top as well. I originally tried using an audio amp from Sparkfun, but the quality wasn't very good so I've removed it until I figure out an alternative. In the meantime, the wires are bundled together and secured with kapton tape.
    Shown above: The upper shell with power switch and speaker.
    Shown below: The lower base and upper shell shown assembled.
  • 3
    Step 3
    Mounting the Internals
    To avoid damaging the casing and to allow future expansion, I made an internal frame that would house all of the other components independently. I modeled it in Sketchup and then laser-cut the design out of 1/8" acrylic.
    Shown above: The internal mounting frame, as designed.
    Shown below: The internal mounting frame, finished.
    The walls of the frame are held together with tape, which seems to work well enough for stability. The ODROID-W and USB hub are mounted to the sides using screws and threaded inserts. The power converter is mounted to the floor in the same manner. The audio amp was mounted to the top using zip-ties, but I removed it prior to taking these photos. The excess 5V power wires are secured against the step-down converter with more kapton tape for future use.
    Shown above: Alternate view from the rear, as designed.
    Shown below: Alternate view from the rear, finished.
    Shown above: The frame is inserted into the assembled lower base and upper shell.
View all 7 instructions
jeromekelty wrote 10/02/2015 at 18:26 point
That is pretty freaking cool.
Arduino Enigma wrote 09/30/2015 at 21:31 point
This is teh awesome!
zakqwy wrote 09/28/2015 at 16:07 point
This is great! My childhood family computer was a Quadra 610 running 7.1. Time to install HyperCard and Maelstrom!
Yann Guidon / YGDES wrote 09/28/2015 at 04:04 point
Oh and you could add a SD card slot in place of the diskette slot :-)
Aaron wrote 10/02/2015 at 18:31 point
Not a bad idea, thanks!  The challenges for me would be cutting the slot open without it looking sloppy and also figuring out a way to auto-mount volumes within Basilisk II.  I've got all the parts for a V2 though, so I'll see what I can do!
