The next step
A project log for Alternate Firmware for FG-100 DDS Function Gen
Reverse engineer the FG-100 pinout and develop alternate firmware that improves some of the shortcomings of the default firmware.
Tim SavageTim Savage 02/14/2017 at 14:430 Comments
At the end of the road for this project, I've moved on and started the Funktion Generator project, this project that will utilise multiple microcontrollers with one doing DDS synthesis and anothiner driving the UI, this allows for adjustments on the fly etc. Good progress has already been made, with the power supply (with +-9V rails) built and working, and the firmware for the DDS generator running and accepting commands vi I2C/TWI.
See: https://hackaday.io/project/19866-funktion-generator
