Hackaday.io Hackaday.io
Sign up Log in
Arduino Controlled LED Baby Mobile
This is my first try in making Toys. I am building a baby mobiles with LED's which are controlled by an Arduino and an old Apple Remote.
mario-lukasMario Lukas
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.7k views
0 comments
1.6k followers
  • Description
  • Details
  • Files 0
  • Components 8
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
2.7k
0
1.6k
7
Team (1)
  • mario-lukasMario Lukas
Join this project's team
MISC
ongoing project
toy arduino apple remote ir led laser cut
This project was created on 10/12/2015 and last updated 8 年前.
Description
This is my first try in making Toys. I am building a baby mobile with LED's which are controlled by an Arduino and an old Apple Remote. I vectorized some nice drawings, i found with google. Then i laser cut the drawings in plywood and acrylic. Three layers for each figure/drawing. Afterwards i glued the parts together and i glued a 3mm LED in the middle plywood layer. I am planing to use an Arduino (mini) and an old Apple remote to control the mobile. The remote can be used for dimming and switching on all or single LED's of the mobiles. Hopefully i can finish the whole thing until next week.
Components
  • 1 × Plywood some pieces
  • 1 × LED one for each figure
  • 1 × wires
  • 1 × Small power supply or Battery
  • 1 × Arduino (mini/nano) whatever
View all 8 components
Project Logs
Collapse
  • Make Light Challenge 2015
    Mario Lukas • 10/29/2015 at 13:04 • 0 comments
    I submitted this project to a german maker contest called "Make Light Challenge 2015". You can vote for me by liking the article behind the following project link : http://www.photonik-campus.de/projects/led-baby-mobile/
    If you like the project it would be great if you also share the link at FB.
    Thanks.
  • Finished a first version.
    Mario Lukas • 10/22/2015 at 12:45 • 0 comments
  • All needed parts
    Mario Lukas • 10/13/2015 at 22:09 • 0 comments
    After a few hours of work in our local fablab, i finally have all the needed parts for the mobiles.
  • Apple Remote and Arduino Test
    Mario Lukas • 10/12/2015 at 17:15 • 0 comments
    I just got an old Apple remote working with an Arduino. Now i have all parts to finish the mobiles.
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Hackaday Prize 2020
how to build LED chaser using arduino uno
Project Owner Contributor
Multiple RGB Led Chaser with Arduino Uno
spark-buzzerspark buzzer
I made an RGB Rocket Smoke Night Lamp, In this lamp, The pattern of light and color can be changed by mobile phone via Bluetooth.
RGB Rocket Lamp Controlled with mobile via HC-05
vishal-sonivishal soni
This fun diy project utilizes Arduino Nano and addressable LED strip to create custom cool light show.
Hoverboard Digital LED Lighting
martinMartin
I made an RGB pumpkin wall light, which can be controlled by a smartphone via Bluetooth, it has different modes and different colors so you
Bluetooth Controlled RGB LED Lamp
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Arduino Controlled LED Baby Mobile", please tell us the reason.
Send message
Remove Member
