Got the backbones too
A project log for Discrete YASEP
a 16-bits YASEP computer (mostly) made of DIP/SOIC chips like in the 70s and 80s... with 2010's twists!
Yann Guidon / YGDESYann Guidon / YGDES 10/21/2016 at 12:170 Comments
After Progress, at last !, I went looking for "ribs" (or "fishbones") or the backbone of the system.
I found extra-long pins on eBay in sufficient quantities, smaller than what I have in stock but still enough to stack 5 pages. It should be enough for the first implementations...
The main PCB could serve as P1A/P1B... or something else requiring a rigid/solid base, connectors etc. so that makes 6 pages.
I received samples from Würth Elektronik !
Thanks to the cool rep, we found a reference that is longer than the previous ones, almost 40mm (so the above picture is a reminder for the reference for a next order)
I might have also found very interesting prototype boards that can be slightly bent...
