The emulated slave CPU can't use the mask ROM at this point in time due to the 6301 core being incomplete and not handling serial ports properly, but since the master and slave communicate only via a serial link this has been simulated by just handling the serial protocol instead. However this adds some limitations, preventing the use of commands locked behind the so called special command mask which allows read/write access to the slave CPU's memory and setting the program counter.
Pontus Rodling
Bernhard "HotKey" Slawik
Arrow Westervelt
gbm
