Radio module arrives
11/06/2015 at 08:35 • 0 commentsAs luck would have it just after creating this project earlier today I received the TEA5767 FM Radio module that I am keen to test out. Instead of buying the raw FM module, I bought it incorporated with a TDA1308 Class AB stereo headphone amplifier on the same module. There are two 3.5mm sockets, one is the headphone amp output, the other is a 3.5mm --> antenna input.
