​Initial Recon
A project log for LED Matrix Controller
Replacing an old Lightlink/Inova FPGA Scrolling LED board controller with PIC24F + ESP8266
yadid-ramotYadid Ramot 11/08/2015 at 20:150 Comments
Original board
  1. Both displays use the same old (circa' 96) control boards made by LightLink / Inova
  2. Controlling board has a 10baseT interface (multiple ports)
  3. When light up + connected to a router, both signs display an IP address information
  4. Port scanning returned nothing.
Device info
after a quick google search i found that these screens connect via UDP - but no luck finding the packet format / protocol
I`ve decided to rebuild the controller board using a simple PIC + ESP8266 combo and write my own protocol for the display
