Scania 4-Series Opticruise for ETS
A project log for Real Scania Truck Home Simulator
The Scrapyard and Arduino make a great combination!
jeroen-van-der-veldenJeroen van der Velden • 03/25/2018 at 19:48•0 Comments
Hi folks!
Today I show you my Scania 4-Series Opticruise working in ETS2. In fact, it will work on any Simulator due to the use of an Arduino Leonardo which Windows will recognize as a HID device (keyboard). I programmed Shift up to "Right Shift" and shift down to "Right CTRL" which are the ETS2 default keys for shifting gear!
Have fun!
Arduino Leonardo Code:
#include "Keyboard.h"
#define SHIFTUP_PIN   2
#define SHIFTDOWN_PIN   3
// Works on the Leonardo board
// Build by Jeroen van der Velden
// https://hackaday.io/project/8448-real-scania-truck-home-simulator
static void ShiftUp(void)
    Keyboard.press(KEY_RIGHT_SHIFT);
static void ShiftDown(void)
    Keyboard.press(KEY_RIGHT_CTRL);
void setup(void)
    Keyboard.begin();
    // Set pin to input
    pinMode(SHIFTUP_PIN, INPUT);
    // Enable pullup resistor
    digitalWrite(SHIFTUP_PIN, HIGH);
    // Set pin to input
    pinMode(SHIFTDOWN_PIN, INPUT);
    digitalWrite(SHIFTDOWN_PIN, HIGH);
void loop(void)
    static uint8_t shiftUpStateLast = 0;
    static uint8_t shiftDownStateLast = 0;
    uint8_t shiftState;
    shiftState = digitalRead(SHIFTUP_PIN);
    if (shiftState != shiftUpStateLast) {
        shiftUpStateLast = shiftState;
        if (shiftState == 0) {
            ShiftUp();
            delay(100);
            Keyboard.releaseAll();
    shiftState = digitalRead(SHIFTDOWN_PIN);
    if (shiftState != shiftDownStateLast) {
        shiftDownStateLast = shiftState;
            ShiftDown();
            delay(100);
    delay(50);
