Retarder Handle Part 3
A project log for Real Scania Truck Home Simulator
The Scrapyard and Arduino make a great combination!
jeroen-van-der-veldenJeroen van der Velden 12/12/2015 at 18:350 Comments
We are getting close my friends!
The code below stores and tells us the position of the retarder handle and it works perfect!
Connect the Retarder to an Arduino Leonardo:
Retarder PIN 2 to 5v
Retarder PIN 6 to gnd
Retarder PIN 7 to A0
int analogPin= 0;
int raw= 0;
int Vin= 5;
float Vout= 0;
float R1= 10000;
float R2= 0;
float buffer= 0;
void setup()
Serial.begin(9600);
void loop()
byte handlePos;
int val = analogRead(0);
  if(val < 187)
      handlePos = 0;
      Serial.println("handlePos = 0");
      Serial.println(val);
    else if(val < 350)
      handlePos = 1;
      Serial.println("handlePos = 1");
    else if(val < 518)
      handlePos = 2;
      Serial.println("handlePos = 2");
    else if(val < 679)
      handlePos = 3;
      Serial.println("handlePos = 3");
    else if(val < 861)
      handlePos = 4;
      Serial.println("handlePos = 4");
    else if(val < 1024)
      handlePos = 5;
      Serial.println("handlePos = 5");
    else
    Serial.println("handlePos unknown");
    delay(500);
// by Jeroen van der Velden
// https://hackaday.io/project/8448-real-dashboard-truck-simulator
Download link to Arduino IDE file
Next and final challenge: send keyboard commands "+" and "-" (retarder "up" and retarder "down")
