ACC / EDC Cruise Control Final!
A project log for Real Scania Truck Home Simulator
The Scrapyard and Arduino make a great combination!
jeroen-van-der-veldenJeroen van der Velden 02/22/2016 at 18:420 Comments
Progress!
Parts Required:
1x Arduino Leonardo
1x Scania Part 1402449
1x 220 ohm resistor
Arduino IDE Code:
//Copyright Jeroen van der Velden 2018
//Released under by-nc-sa Non-Commercial Share Alike
//https://hackaday.io/project/8448
#include "Keyboard.h"
int lockpin = 13;
bool oldstate=false;
bool debugmode=false;
bool keystate=false;
char outchar=' ';
const int acctrip = 200;
const int restrip = 400;
const int rettrip = 600;
const int onlimit = 700;
const int offlimit = 890;
void setup() {
  pinMode(lockpin,INPUT_PULLUP); //no need for a pullup.
  // open the serial port
  Serial.begin(9600);
void loop() {
  int analogValue = analogRead(A0);
  debugmode=digitalRead(lockpin);
  if (debugmode==false)
    Keyboard.begin();
   else
    Keyboard.end();
  if (analogValue>offlimit)
    keystate=false;
    else keystate=true;
  if (oldstate != keystate)
     {oldstate=keystate;
       Keyboard.write('c');
       else
       Serial.println ('c');
  if ((analogValue <= onlimit)&&(analogValue>=acctrip))
   {if (analogValue>rettrip) outchar='8';
      else if (analogValue >restrip) outchar='7';
       else if (analogValue>acctrip) outchar='9';
      Keyboard.write(outchar);
      else
      {Serial.print(outchar);
       Serial.print("  ");
       Serial.println(analogValue);
    //analogvalue in keyscan limit
      else
      {Serial.print("No char ");
    delay(150);
How to wire:
Connect the White and Black/Purple wire to the Arduino. White goes to GND and Black/Purple goes to the 220 Ohm Resistor.
From the resistor, go to 5v
Between the Black/Purple wire from the lever and the 220 Ohm resistor go to A0 (Analog input 0).
