A little late posting here, but just a heads-up that revision 7 has arrived and is making its way to various distribution channels!
![](https://cdn.hackaday.io/images/6846011633017813556.jpg)
New 4-layer PCB, much more decoupling capacitance on-board, RTL8201FI Ethernet Phy and now 16 MB of flash!
Tindie: https://www.tindie.com/products/silicognition/wesp32/
Amazon: https://www.amazon.com/Silicognition-wESP32-Isolated-Ethernet-802-3at/dp/B084RV91NQ/
Note that the lead time shown on Mouser is bogus, they had 100 units shipped to them already. Should ship much sooner than the lead time indicates.
Fast credit, an unbeatable rate from 2%
You need money urgently, get now up to €100,000 in a few hours to solve all your personal problems.
From a few thousand euros to several hundred thousand euros with a rapid decision and provision of funds
Professional loan
Between 30,000 and 50,000,000 euros
Repayment duration between 6 months and 20 years
Do not exist contact us by email:agricolecredit527@gmail.com
I'm a beginner with the wESP32 board . My problem is that I can upload a program only once and then the board won't accept another program. I'm using Visual Studio Code on Windows with the Platformio IDE and the Arduino platform. The first program (a wifi scanner) loads and runs just fine but subsequent attempts end with a serial port communication error. Yes, Windows and the IDE can find the port (COM5 on my machine), and yes the serial monitor has no problem reading input from the wESP32 on that same port (baud = 115200). What am I doing wrong?
I've tried using a different platform (Expressif IDE) with the same result. I've also tried specifying the COM port and the baud rate (9600) in the platformio.ini file. No luck.
Hi, I'm sorry but I have no idea why this might be happening. Are you using the accompanying wESP32-Prog or wESP32-Prog-C programming module or a third party programming module? If third party, does it have the auto programming circuitry?
Patrick, thanks for your reply. I've been trying to use the Expressif IDE but within Visual Studio Code. I'm now trying to use the standalone Expressif IDE to see if that helps. One problem I'm having is choosing a processor type. The options are esp32, esp32-c2, esp32-c3, and esp32-h2. Do you know which I should use with the wESP32 module? My board's processor is ESP32-WROOM-32E. Thanks!
It's the ESP32 without suffix
Patrick, it was the board (or the attached serial port), not the IDE. I tried three different IDEs (VS Code, Arduino, Expressif) with the same result but everything works just fine when I switched to using a new wESP board. I don't know if there's a defect in my first board, or just with the programming port but at least I have a working system for now. Thanks again for your help.
Odd, since they are all supposed to be tested during production.
Do you have the programming module in a socket or connected to a header, or soldered in, or just pushed in to the staggered footprint held by friction? The latter does not always work reliably unfortunately.
Hi,
I have 3 brand new boards with revision 7 at my desk. One of them works fine, but the other two are not working. I am getting the error "Serial data stream stopped: Possible serial noise or corruption".
The other board is programmed, but does not run in normal mode and throws error "
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2)) waiting for download"
How I can make fixes of these?
