wESP32-7-CCBYSA.pdfSchematic of wESP32 rev 7 with RTL8201 Ethernet PHYAdobe Portable Document Format - 43.26 kB - 01/14/2022 at 18:15 |
wESP32-3-mechanical.pdfMechanical drawing of the wESP32 rev 3Adobe Portable Document Format - 88.38 kB - 01/07/2020 at 16:37 |
wESP32-Prog-1-Eagle.zipEagle CAD source files of the wESP32-Prog programming submoduleZip Archive - 50.43 kB - 10/07/2019 at 14:41 |
wESP32-Prog-1.pdfSchematic of wESP32-Prog programming submoduleAdobe Portable Document Format - 19.49 kB - 10/07/2019 at 14:41 |
wESP32-3.pdfSchematic of wESP32 rev 3 with PMS150C to manage PHY resetAdobe Portable Document Format - 43.55 kB - 03/19/2019 at 23:10 |
wESP32-1.pdfComplete schematic of wESP32 core moduleAdobe Portable Document Format - 45.40 kB - 04/20/2018 at 18:30 |
lan8720a.pdfEthernet Phy with RMII interfaceAdobe Portable Document Format - 1.02 MB - 04/18/2018 at 18:20 |
cp2102n-datasheet.pdfUSB UART bridge for programming the ESP32Adobe Portable Document Format - 953.87 kB - 03/19/2018 at 18:17 |
P675-9591.pdfPulse Electronics EP13 transformers, I'm interested in the PA2467NL specificallyAdobe Portable Document Format - 1.92 MB - 03/19/2018 at 18:15 |
si3404-datasheet.pdfPoE 802.3af compliant PD / PWM controllerAdobe Portable Document Format - 653.80 kB - 03/19/2018 at 18:15 |
HR861153C .pdfEthernet MagJack with protection and diode bridgesAdobe Portable Document Format - 177.56 kB - 03/19/2018 at 18:14 |
