State of the Matrix
A project log for reDOT_Matrix
A alternative approach to create a multi digit 5x7 LED Matrix Display
AlexAlex 05/12/2018 at 23:210 Comments
Here are some quick images of the current Hardware state: The Grind in the background is 5mm (~0.2'')
Two matrix-PCBs are soldered. They are also working, but I have no good images so far.
The back with the two LED driver ICs, a STM8s microcontroller, pinheader for ESP-01 and USB-connector for power
 Can you spot the mistake on the next image?
Saw it?  The LEDs on the third not soldered Matrix PCB are soldered 180° rotated. This does not work with the main PCB. But sadly the cathode marking on the matrix PCBs is wrong. And I soldered the first five matrix PCBs wrong for the main PCB. With five not usable matrix PCBs I run out of LEDs sadly :(
Like this it should look at the end.
Now I will work on the STM8 firmware. So far only switching all LEDs on is working.
