The target of this project is to raise awareness about climate change.
THINGHTTPCO2.inofirst esp826 sketch to take data from thingHTTPino - 1.82 kB - 03/21/2018 at 21:15 |
the first step of the project is to obtained the co2 level data. To do this, I choose to use the HTTPThing app from thingspeak, that allow to fetch data from every site and make it disponible trough an API.
The MCU that i choose to use is the well know ESP8266. Thanks to the ESP8266HttpClient library i can simply send a GET request to the thinghttp link and receive the daily data from www.co2.earth.
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
const char* ssid = "MYWIFI";
const char* password = "*******";
void setup () {
Serial.begin(115200);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(1000);
Serial.println("Connecting..");
void loop() {
if (WiFi.status() == WL_CONNECTED) { //Check WiFi connection status
HTTPClient http; //Declare an object of class HTTPClient
http.begin("http://api.thingspeak.com/apps/thinghttp/send_request?api_key=YAOX15VANMLMYH4S"); //Specify request destination
int httpCode = http.GET(); //Send the request
if (httpCode > 0) { //Check the returning code
String payload = http.getString(); //Get the request response payload
String todaydate = payload.substring(62,76);
String todayco2 = payload.substring(118,128);
Serial.print(todaydate);
Serial.print(" CO2 Level: "); //Print the response payload
Serial.println(todayco2);
httpCode == 0;
http.begin("http://api.thingspeak.com/apps/thinghttp/send_request?api_key=3TKGGW5Z5CHH7G0S"); //Specify request destination
String agodate = payload.substring(36,50);
String agoco2 = payload.substring(92,99);//Get the request response payload
Serial.print(agodate);
Serial.println(agoco2); //Print the response payload
http.end(); //Close connection
delay(30000); //Send a request every 30 seconds
However co2.earth only maintain data histories about last year. So for the decade CO2 data i will use a text file downloaded from noaa server that contain world CO2 data from start of 20th century.
