Playback version of the code
A project log for Schlieren-Videography
With this project I want to show you how you can make Schlieren-Videography at home. To do so we will use the Moiré-effect.
jana-marieJana Marie 05/15/2016 at 18:160 Comments
There is now a playback version of the Processing sketch, with which you can record a video and then calculate the schlieren-effect afterwards. The raster-screen is still required.
This version of the code works great with higher resolutions, as it doesn't need to be played live.
