1Step 1
- Download and install WTware for Raspberry Pi 2 and 3 on server
2Step 2
2. Run on server WTware graphic configurator, press button and create SD card for local or network boot using WTware wizard:
3Step 3
3. Insert card into Raspberry Pi 2.
4Step 4
4. If you don't use WTware DHCP service and want to boot by network, specify in DHCP 067 parameter:
5.4.14\kernel7.img
5Step 5
5. Turn Raspberry Pi 2 and 3 on.
