- One servo to control the throttle and choke.
- Servo to apply the disc brake.
- One linear servo is used to control the lever to the transmission
- the other linear servo is for disengaging the drive belt through the idler.
- The high torque servo is used for steering. Its connected to the pinion gear through the steering shaft.
Looks like you could do with my control system?
