backpacket
experiment with data over radio
Currently based heavily on the MicroModem (<a href="http://unsigned.io/projects/micromodem/" target="_blank">http://unsigned.io/projects/micromodem/</a>), the aim is to also send data from bluetooth connected devices over the radio.
teraz wrote 01/13/2022 at 19:15 point
In my opinion I need raspberry pico 2040 (or similar with minimum 512KiB ram) because have more ram
for example ruby or other language. this device must run many protocol many network therefore softweare is very importantn (tnc, direwolf linux etc.) Why not put screen and small keyboard? Simple keyboard similar old cell phone.
Second question is wire. why not put mic and audio output? for example for dewice without any input source audio. ok this is not good but if You dont have any device but have normal radio or walkie talkie without connector?
look this https://www.adafruit.com/product/4074
and http://www.whence.com/minimodem/
