The Portable Raspberry Pi Tor Router can be used by any device with a wireless internet connection, and was inspired by the Onion Pi by adafruit, linked in the link section. The build was roughly the same as the Onion Pi, with adjustments to make it all run smoother, as well as the addition of an external battery. You can also change where you want to browse from in the world (Ex. Germany or the Netherlands) or leave it up to Tor, which will randomize the process.
Josh Starnes
Initial State
Its very amazing idea I really impressed by your approach keep it up and if you need any information about routers just visit routerinsider for detailed guidance.
