ESP32 Bluetooth A2DP SRC
Using ESP-IDF to send raw PCM data to a fidget spinner
This initially started as an attempt to get 4-bit SDIO working on an ESP32. I noticed an A2DP-SRC example that sent random data to a sink in the IDF and decided it could be a bit better.
Linked below is my hack to the example A2DP-SRC code so that it streams raw PCM data from a SD card. Also linked below is a video on YouTube of it playing the Super Mario Bros. theme song.
LAMICHHANE-SUMAN wrote 03/14/2024 at 00:41 point
Would it be possible to see any source code?
Omar BENHAMID wrote 04/25/2020 at 05:36 point
Source is here : https://github.com/gtalusan/esp-idf/tree/master/examples/bluetooth/a2dp_source
The author put it in links on the left but it is not very visible thow.
Alex wrote 11/09/2018 at 01:24 point
Steve wrote 09/13/2018 at 00:04 point
Could you share these files?
