Composino
CPLD is perfect for you? MCU is perfect for you? Both are put together!!
Before I made a very easy CPLD prototyping board, where circuit implementation file (.svf) can be downloaded to CPLD through FTDI chip. Indeed 95288XL is enough large to implement relatively complex circuit (4-bit CPU and peripheral) but sometimes I got to know “easy operation” of ready-made CPU such as AVR ATMega. This time I made “Composino” consisting of Arduino compatible part and CPLD part, and those are internally connected and enables complex prototyping. MCU cannot be "device". CPLD cannot be (can be, but not optimised and multifunction) MCU. CPLD can be "device!" and MCU can handle SPI, I2C, A/D by single chip! Combination will make us happy!
  • Structure of “Composino”
    The above figure shows the configuration of Composino. D2 to D9 (Arduino naming) of ATMega328P is connected to XC9572XL from P1 to P12. Connecting A/D input to CPLD is not useful and those has direct output. In addition, SPI and I2C(included in A/D) has direct terminal on board. If some “SPI design by CPLD” is required, we can just connect D10 to D13 to XC9572XL pins by jumper wires.
Confirmation of basic operation by 7-segment LCD driver
Actually SPI and I2C of ATMega328 is still alive and we gain infinite (limited to CPLD cell size, though) possibility by this wonderful combination. Just to see its fundamental operation, 7-segment driver and counter is made in Composino. (Please note that simple LED segment driver is NOT at most what we can do by this board..) In this confirmation, CPLD part has simple source as follows:
module SEVENSEG(
    input [3:0] SW,
    output reg [7:0] nSEG
always @* begin
	case( SW )
	4'h0: nSEG = 8'b11000000;
	4'h1: nSEG = 8'b11111001;
	4'h2: nSEG = 8'b10100100;
	4'h3: nSEG = 8'b10110000;
	4'h4: nSEG = 8'b10011001;
	4'h5: nSEG = 8'b10010010;
	4'h6: nSEG = 8'b10000010;
	4'h7: nSEG = 8'b11011000;
	4'h8: nSEG = 8'b10000000;
	4'h9: nSEG = 8'b10010000;
	4'ha: nSEG = 8'b10001000;
	4'hb: nSEG = 8'b10000011;
	4'hc: nSEG = 8'b11000110;
	4'hd: nSEG = 8'b10100001;
	4'he: nSEG = 8'b10000110;
	4'hf: nSEG = 8'b10001110;
	default:nSEG=8'bxxxxxxxx;
	endcase
end
endmodule
with following .ucf file
NET "nSEG<0>" LOC="P34";
NET "nSEG<1>" LOC="P33";
NET "nSEG<2>" LOC="P32";
NET "nSEG<3>" LOC="P31";
NET "nSEG<4>" LOC="P30";
NET "nSEG<5>" LOC="P29";
NET "nSEG<6>" LOC="P28";
NET "nSEG<7>" LOC="P27";
NET "SW<0>" LOC="P1";
NET "SW<1>" LOC="P2";
NET "SW<2>" LOC="P3";
NET "SW<3>" LOC="P5";
These source realising 7-segment LED driver, where “P1”, "P2”, “P3” “P5” are binary input and segment out are P27 to P34. As mentioned,
P1 to P5 are connected to D2 to D5, and binary number is generated by following Arduino source,
void setup() {
  for(int i=2;i<9;i++){
  pinMode(i, OUTPUT);
void loop() {
  byte count;
  boolean a, b, c, d;
  for(count=0; count<17;count++){
    a=count&0b0001;
    b=(count&0b0010)>>1;
    c=(count&0b0100)>>2;
    d=(count&0b1000)>>3;
    digitalWrite(2, a);
    digitalWrite(3, b);
    digitalWrite(4, c);
    digitalWrite(5, d);
    delay(2000);
The actual operation can be found in the following movie… Have fun!
default.svf
svn file generated by .v and .ucf files
svf - 196.13 kB - 01/31/2016 at 14:22
Download
Composino_test1.ino
Arduino sketch to see operation (counter)
ino - 407.00 bytes - 01/31/2016 at 14:22
Download
SEVENSEG.ucf
ucf file for 7seg driver
ucf - 300.00 bytes - 01/31/2016 at 14:22
Download
SEVENSEG.v
seven segment LED sample
v - 1.08 kB - 01/31/2016 at 14:21
Download
Composino.sch
Eagle schematic
sch - 452.41 kB - 01/31/2016 at 14:21
Download
View all 6 files
  • Component information
    kodera2t08/01/2016 at 11:04 0 comments
    Thank you for supporting my creation activity. I started to sell Composino at tindie.com but I've forgot to clarify capacitance values in composino. Here is the information:
    I just use five capacitors and one resister. Except for DTR line, all the capacitors are 1uF and only one resistor is 10k. Thank you!!
View project log
pradip wrote 05/13/2023 at 00:14 point
fpga altera ii firmware read and write to another altera max ii. How its possible please suggest all step. Please
Harry Svensson wrote 07/16/2016 at 14:03 point
That pcb layout gave me cancer.
Reason: 90 degree angles => ouch.
kodera2t wrote 07/16/2016 at 23:43 point
So sorry for that.
