The commercial side of this thing
A project log for Brushed DC Servo Drive
Low cost PID servo drive for small CNC machinery
ottoragamottoragam 06/03/2016 at 23:520 Comments
I've been working with James Newton, of Linnistepper fame, on an open source commercial low cost closed loop motor conversion system. An encoder board is available for sale, along with a PIC based PID controller.
https://cdn.hackaday.io/images/5569361461622297516.jpg
The relevant links are here:
Hakcaday.io project
https://hackaday.io/project/11418-massmindorg-abosoluteincremental-rotary-encoder
Purchase here!
http://techref.massmind.org/techref/io/sensor/pos/enc/ENC1.htm
http://techref.massmind.org/techref/io/servo/BOBPID.htm
This project may also be of interest to some of you. It is a low cost 40V 18A H bridge based on the same FET driver as my smaller servo drive project, with some easier to cool transistors.
https://cdn.hackaday.io/images/5344591461622861291.jpg
https://hackaday.io/project/11419-massmindorg-40-v-15-a-output-dc-motor-drive
