WiFi Socket prototype based on SUPLA and ESP8266
ESP8266 & SUPLA
What will we need?
Do not forget to connect the ESP module TXD pin to the USB-Serial converter RXD pin, and the ESP module RXD pin to the USB-Serial converter TXD pin. “IN1” must be connected to the relay module.
Solder the ESP8266-12 module to the PCB adapter
With a thin wire make hookups for easier module pin connections.
