Please test tizen-common-core-image-minimal
A project log for Port Tizen to Raspberry Pi Zero
Start from 0 to other raspberry pies (1,2,3..)
rzrRzR 02/18/2016 at 06:550 Comments
ARMv6 port is booting on RP1 see video
https://vimeo.com/151030672#tizen-raspberrypi1a-20160107rzr
Next step would be to try on zero, so if any of you knows where to get one , or want to try it please contact me I will share software
Please get
tizen-common-core-image-minimal-raspberrypi0-20160218053214.rootfs.rpi-sdimg.qcow2
https://wiki.tizen.org/wiki/User:Pcoval/Files
I will double check if it's building and if's ok I will split the file and host it here as well and refresh sandbox/pcoval/raspberrypi0 too.
