![](https://cricraft.files.wordpress.com/2023/12/how-to-make-a-cricut-new-year-card-quick-and-easy-guide.png)
During the New Year, everyone likes to send greeting cards to their loved ones, and I do too. But making it is a difficult task. If you are a Cricut user, then you can easily create your own Cricut New Year card in just a few minutes. Also, I have made a custom card on Cricut Joy. Yes, you heard that right! This mini Cricut Joy is capable of cutting more than 50 materials.
Moreover, I recently finished creating a greeting card; I will now teach you how to make your own card. The process is simple and easy, and a beginner can make it on their own. Be it essential supplies or step-by-step tutorials, I have tried to explain everything in the easiest way possible. So why wait? Let’s dive deeper into it!
What Cricut Supplies Will You Need for Making a Card?
When I started making cards, I collected all the essential accessories, tools, and other items that I needed. Below, I have mentioned the supplies required for making a Cricut New Year card. Have a look at it:
- Cricut Joy (or Maker & Explore series)
- Cricut Design Space software installed on the computer
- Cardstock or Thick paper
- Cricut Joy Mat
- Vinyl
- Cricut Tool Set
- Cricut Bright Pad (optional)
- Insert Card
How to Make a Cricut New Year’s Card?
So, ready to start your project on Cricut Joy? Below, I have provided detailed instructions to create a beautiful card, so look no further than the tutorial given below:
Step 1: Upload SVG File or Create Your Own Design
The first step includes uploading a ready-made Cricut design. You can get this SVG from the internet, or you can use Cricut’s free resources to make your own. Other than that, you have the option to create your own design on Design Space.
If you want to upload an SVG file, then you need to follow the steps mentioned below:
- Open the Design Space and go to the Canvas; there, you will find the “Upload” panel.
- After that, you have to click the Browse button.
- Then, you will be redirected to the folder where you have downloaded your SVG file.
- After that, the design will be added to Design Space.
- Here, you can edit your design as per your requirements, such as resizing the size of the cards and adding elements.
Step 2: Prepare the Card Mat
In order to make a beautiful Cricut New Year card, you have to load the pre-cut card onto your card mat.
You will find the top layer is sticky and looks like a LightGrip Mat, so you have to fold the top of the card onto itself and you need to press it down.
Tip: Ensure you need to take the time to align the folded card with the pre-printed lines on the card mat. This way, you can make your design perfect!
Step 3: Cut and Weed Out the Design
Once you are ready with your design, you have to press the Go button on the software. After that, your Joy machine will start cutting the design on your loaded cardstock material. After cutting, all you need is to weed the cut design gently and remove the extra materials that are not required. Make sure you are using the right tool to weed your material, such as weeders and tweezers.
Step 4: Assemble Cards
Now we have done our cutting, it’s time to assemble them so that it looks visually appealing. For this, I have chosen this insert card that easily fits into the four cutout corners.
The contrasting paper gives it a much better look than other papers.
Last but not least, if you are thinking why I have added congrats on my greeting card, then it is because I want to congratulate someone. This is no one but my son who scored good marks on his math test. Therefore, I tried something for this New Year.
Besides, you will find a lot of space inside the card where you can wish and express what you want. So, transform the Cricut New Year card into an extraordinary card with a Cricut Joy and spread the Joy of the festive season.
FAQs
Can I make a New Year card with Cricut?
Absolutely! Whether it is a New Year project like a banner, cake topper, or cards, everything is possible with the Cricut machine. Moreover, you can make cards with your Joy, which costs really less, and it will easily fit your budget. Also, if you are in a hurry and don’t want to create those complex designs, then Cricut has a solution for you. You just need to go to the Design Space, where you will find the ready-made designs. You can add them to your canvas and edit them as per requirements.
What machine should I use to make a New Year greeting card?
If you want a cutting-edge result that looks professional and fits your budget, then you need to use the Cricut Explore series. Also, it would be a great choice for you if you want to cut materials like vinyl, iron-on, and paper to make your projects. Otherwise, if you want to go with a more affordable option, then it is your Cricut Joy. It is not only cheap but capable of making your cards with precise cuts.
Is it easy to make last-minute Cricut Joy New Year cards?
It depends on your design; if it is simpler and there are not many elements to be added, then you can make it within a minute; otherwise, it can also take up to 30 minutes. However, Cricut is made to make your task easier, so yes, it is not very difficult to make any cards for the New Year.
Wrapping Up
Finally, I have covered this complete tutorial on how to make a Cricut New Year card. This tutorial is helpful for both beginners and pro-experienced crafters. The tutorial also covers the essential supplies needed to create a personalized Cricut New Year’s card. Despite this, I have explained each step in the easiest way that guides you to make your own card hassle-free. New Year comes once a year, so don’t miss the chance to bring happiness to your loved ones.
For more information visit: Cricut.com setup joy
cricut.com/setup explore air 2
Source: Cricut New Year Card
