Good luck guys; gear up yourself to be a part of a thrilling ride comparing Cricut machines. The main goal of writing this blog is to help my sister by guiding her to invest money in the right Cricut machine setup. For the past few years, the company has developed different models of Cricut machines. Before taking a step into the world of crafting, my sister needs to compare all Cricut machines without skipping any pointers.
After differentiating among all the models, it will be easier for her to make a final decision about the compatible Cricut machine. Whether you have a small or big project, there is always a craft plotter that turns imaginable projects into reality. So, study this blog now and choose which Cricut cutting model is going to be suitable for homemade projects.
Cricut Maker Versions
Beginning with the Cricut Maker is one of the most powerful and costly cutting models ever developed by the company. This model is highly preferred by the experts for producing highly professional-level crafts. Also, the Maker cutting machine is the most versatile model available in the market. With the help of its bundle and tools, this craft model cut more than 300 materials with precise and clean cuts on the corners. Besides, Maker can do more than write and cut that is beyond your imagination.
Cricut Maker 3 isthe new version of the Maker model that was launched in 2021. If you compare Cricut machine models to its predecessor, it is a much more powerful, faster, and smart cutting machine for every kind of craft. This Cricut cutting machine swiftly and accurately cuts more than 300+ materials and is compatible with Smart Materials. On the other hand, it performs like a champ, even on the complicated cuts. Plus, this Cricut Maker 3 can not only cut or write but also score, foil, and engrave on the materials.
Cricut Explore Versions
Next up, while talking about comparing Cricut machines, comes Cricut Explore 3. It is a DIY dream machine of all the crafters. This craft plotter impresses them with its incredible speed and precision. Also, it works with 100+ materials and provides eye-catching crafts that make every DIYer grabbing attention. Also, Explore 3 supports Smart Materials during the cutting process and is easily connected to the home inkjet printer. Apart from that, this Cricut product can write, draw, foil, and score depending upon the command given by the crafter.
Equally important to compare different Cricut machines, you can also refer to the Cricut Explore Air 2. This all-rounder craft machine is capable of cutting 100+ materials making all the DIY dreams come true. Explore Air 2 is the best choice for all the newbies and a fabulous full-size machine in the craft market. Undoubtedly, it has a Print Then Cut feature but isn't compatible with Smart Materials. Finally, it works with six tools to cut, write, score, and foil during the process.
Cricut Joy Versions
Focusing on comparing Cricut machines, Cricut Joy turns your innovative ideas into action within a few minutes. This small, mighty, cute, and portable smart cutter cut 50+ materials precisely and accurately. Besides, the Joy cutting machine is lightweight, portable, and fits in tight places. Plus, it is compatible with Smart Materials that come in a variety of colors and styles. Other than that, Cricut Joy's built-in Bluetooth feature connected devices with its Joy app.
In this list, you can also add the Cricut Joy Xtra cutting machine model. The Cricut Joy model came into the market in 2023. Just like its previous version, this cut-die machine is portable but a little heavier and more prominent in size. In addition, Cricut Joy Xtra also cuts 50+ materials with precision without making any mistakes. Also, it has a Print Then Cut feature and easily connects with the home inkjet printer. This Cricut Joy latest model not only cuts but also writes, draws, and foils as per the directions given by the crafter.
Cricut Venture
Finally comes Cricut Venture, which expands the creativity level and motivates the DIYer to increase their crafting level. Presently, it is one of the largest and fastest cutting machines currently available in the Cricut models. Venture cutting machine is a wide-format professional Cricut product that cuts 100+ materials within 15 minutes. This craft plotter handles accuracy while cutting or drawing upto 25 inches/second. The Cricut Venture machine can also write, foil, and score. The DIYer can try this smart cutting machine with a Docking stand for more flexibility.
Being an expert in this crafting world, let me share with you that the design software that supports all of these craft plotters is the Design Space app. Simply put, it is digital software providing a library with cost-free images, fonts, and personalized projects.
Conclusion
As a result of comparing Cricut machines, all of the models mentioned above are excellent in their respective places. All of these versions are great and can't beat another one when it comes to designing any craft. However, it will be your decision which cut-die machine you are going to choose as per your needs. Other than that, you will also find lots of inspiration, projects, and tips that will help you in completing the task within the limited time frame.
Frequently Asked Questions
Which Is the Best Cricut Machine for Beginners?
Seven varieties of smart cutting machines have been developed by Cricut in the past few years. Undoubtedly, all of the models have their features, giving the best results to the users. Talking in terms of beginners, Cricut Joy & Maker 3 are the craft plotters that are considered best by beginners who are new in the crafting world.
What Are the Projects That I Can Make Out of Cricut Joy Xtra?
Since the company has launched Cricut Joy Xtra, it has gained a lot of popularity among users with its brilliant features. Some of the famous projects that can be made out of this craft machine are:
- Greeting cards
- T-shirts
- Mugs
- Tote Bags
- Stickers
- Tumblers
- Wood Sign
- Pillows
- Decals
- Labels
How Can I Connect Cricut Machine to My iOS Device?
Have a look at the following pointers and connect both devices:
- Open your iOS device Bluetooth by going to the Settings tab.
- Now, move the Bluetooth toggle to the right side and wait for your device to scan the nearby devices.
- After scanning is finished, the name of your cutting machine will appear under the Available Devices section.
- Next, select the model, enter the password, and hit the Pair button.
- You will receive the message that your devices are connected successfully with each other.
- Finally, you can now send the commands to the machine during the crafting process.
For more information visit: Cricut.com/setup app
Source: Comparing Cricut Machines
