Know SQL Injection Hacking Techniques And How To Prevent It
Productivity - May 14, 2017, by -Tommy Sinaga
As I used to say, to become a professional hacker, you need to master a lot of hacking techniques. Because it is usual target hackers themselves use a lot of cyber defense system.
One of the most frequently used hacking techniques, SQL injection. As to whether this SQL injection attack method, then how to prevent it. Want to know? Let's see more about my discussion below!
SQL injection is a hacking technique aimed at attacking SQL server databases. The trick is to use the loophole placement SQL server code, by entering malicious code through input into a site page.
Adding Jaka's explanation just now, this is a common technique used to attack a site. How to avoid this attack. That is if you have a site, must pass the SQL injection vulnerability test test.
For a simple demonstration of how to attack with this technique, you can see it through the following video.
